AW: [Qgis-developer] advanced printing branch 2
John C. Tull
john.tull at wildnevada.org
Tue Jan 27 15:53:52 EST 2009
Marco,
Sorry, I meant to report back on this. I have not seen the problem
since you merged with trunk.
John
On Jan 27, 2009, at 1:04 AM, Marco Hugentobler wrote:
> Hi John,
> I tested on a G4 with OS 10.4 and Qt 4.4.1.
> Everything seems ok with the template save dialog for me. As long as
> the save
> dialog has focus, the shortcuts are not applied.
> I don't know what the critical difference is between your
> installation and my
> one. Maybe the OS X version, Intel/not Intel Mac or is it the Qt
> version?
> Anyway, it would be good if other Mac user could test the behaviour
> of the
> template save dialog on their system.
> cheers,
> Marco
> Am Samstag 24 Januar 2009 18:41:44 schrieb John C. Tull:
>> I see in the logs that you did the merge this morning. I'll build and
>> test that a bit.
>> Regards,
>> John
>> On Jan 24, 2009, at 9:38 AM, John C. Tull wrote:
>>> It might be that they are, although I had not noticed. Once you
>>> merge into trunk I will try again. Are you still planning that soon
>>> or holding off?
>>> John
>>> On Jan 24, 2009, at 1:21 AM, Hugentobler Marco wrote:
>>>> Hi John,
>>>> Thanks for the hint. On Ubuntu, everything seems ok. As long as the
>>>> main map window does not have focus, the shortcuts are not applied.
>>>> Seems an OS X specific issue. I'm going to try it on OS X next
>>>> week. Maybe also the other file dialogs used in QGIS are affected
>>>> by this problem?
>>>> Regards,
>>>> Marco
>>>> -----Ursprüngliche Nachricht-----
>>>> Von: John C. Tull im Auftrag von John C. Tull
>>>> Gesendet: Fr 23.01.2009 20:32
>>>> An: Hugentobler Marco
>>>> Cc: qgis-developer
>>>> Betreff: Re: [Qgis-developer] advanced printing branch 2
>>>> Marco,
>>>> Today, I noticed that there is at least one problem on OS X. When
>>>> trying to save a composer template, the keyboard inputs are being
>>>> read
>>>> by qgis as shortcuts. I.e., typing a 'h' in a filename does not put
>>>> an
>>>> 'h' character in the dialog box but hides all the layers on the
>>>> map.
>>>> This is with your most current advanced printing branch code.
>>>> Regards,
>>>> John
>>>> On Dec 24, 2008, at 5:57 AM, Marco Hugentobler wrote:
>>>>> Dear qgis devs,
>>>>> The advanced printing branch 2 is ready to be tested now that
>>>>> feature freeze
>>>>> is over. You can obtain the sources with:
>>>>> svn co http://svn.osgeo.org/qgis/branches/
>>>>> advanced_printing_branch2
>>>>> In the branch, there are some new features (all inside the print
>>>>> composer):
>>>>> - alignment of items
>>>>> - snapping of items to a grid
>>>>> - preview for svg images
>>>>> - composer templates
>>>>> Please report any issues you find with those new features. I'm
>>>>> going
>>>>> to be in
>>>>> vacations for some time and will adress them in the new year.
>>>>> Merry christmas and happy new year,
>>>>> Marco
>>>>> Dr. Marco Hugentobler
>>>>> Institute of Cartography
>>>>> ETH Zurich
>>>>> Technical Advisor QGIS Project Steering Committee
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> ETH Zurich
