[Qgis-developer] QGIS creating defective shape-files?
Thu Jul 23 21:04:27 EDT 2009
Maxim Dubinin wrote:
> 1. The fact that QGIS is showing everything correctly probably means
> that it is simply ignoring spatial index (sbn,sbx) of the
> shapefile, is this so? If so, I'm not sure if this is correct
> strategy, use of this index might help to work with larger datasets.
> As I can see, QGIS is creating its own index (qix), it might mean that
> ESRI spatial index format is not open/effective?
Maxim / Marco, etc,
I would note that there is already a GDAL ticket on the need to delete the
.sbn/.sbx and/or .qix files if the underlying shapefile is changed.
   http://trac.osgeo.org/gdal/ticket/2798
This is on Chaitanya's todo list.
Best regards,
