[Qgis-developer] Bug in Attribute Table for Postgis Data Sources
Jürgen E. Fischer jef at norbit.de
Tue Jun 2 08:04:49 EDT 2009
Hi Andreas,
On Tue, 02. Jun 2009 at 13:40:31 +0200, Andreas Neumann wrote:
> The funny thing is that I can only reproduce the bug for some tables, not
> for all.
Does that only happen for columns that are located after the geometry column?
Most tables probably have the geometry as last column as the attributes are
created first in CREATE TABLE and the geometry column later with
AddGeometryColumn() on the existing table.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
