AW: [Qgis-developer] GRASS bugs commit
Tim Sutton
lists at linfiniti.com
Thu May 14 01:28:23 EDT 2009
Hi
Hugentobler Marco wrote:
> Hi Radim
> Nice to see you are back!
Yes welcome back Radim!
> Bugfixes should go into trunk and also be backported to the stable branch (Version-1_0) if it is possible.
Yes. Note that 1.0 is in feature freeze permenantly, so only bug fixes
go in there.
> Afaik the release branches receive changes related to packaging and release process. After the release, those changes are merged back. Tim knows more about the release process, so maybe he could add/correct.
Thats correct. Branches are made at point or release, or by developers
who want to work in a sandbox. Note that svn doesnt treat branches and
tags any differently like CVS does.
So if you are working in trunk, work here:
https://trac.osgeo.org/qgis/
And in the stable branch, work here:
https://svn.osgeo.org/qgis/branches/Version-1_0
Regards
Tim
> Regards,
> Marco
> -----Ursprüngliche Nachricht----
> Von: qgis-developer-bounces at lists.osgeo.org im Auftrag von Radim Blazek
> Gesendet: Mi 13.05.2009 12:11
> An: qgis-developer at lists.osgeo.org
> Betreff: [Qgis-developer] GRASS bugs commit
> Hi,
> I am going to fix some GRASS related bugs. I was not contributing to
> QGIS for a while so I want to ask you where I should commit the fixes.
> Into 'trunk' I presume? Into some stable branches also?
> BTW, can you please clarify (or point me to some place were it is
> explained) how release branching is done?
> I see Version-1_0 branch which I suppose was used to create
> Release-1_0_0, Release-1_0_1 and Release-1_0_2?
> Release-1_0_1 was created from Release-1_0_0 or from Version-1_0?
> I don't see any Version-1_1 while Release-1_1_0 was created already.
> Why Release-1_x_x are branches, not tags? A release must be unique, right?
> Radim
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
