AW: [Qgis-developer] GRASS bugs commit
Radim Blazek
radim.blazek at gmail.com
Thu May 14 07:03:57 EDT 2009
Unfortunately the changes (still bugfixes only) dont seem to be just
few rows, so I'll submit them to trunk only. Later can be merged to
Version-1_0 when tested by users in trunk.
Radim
On Thu, May 14, 2009 at 7:28 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> Hugentobler Marco wrote:
>> Hi Radim
>> Nice to see you are back!
> Yes welcome back Radim!
>> Bugfixes should go into trunk and also be backported to the stable branch
>> (Version-1_0) if it is possible.
> Yes. Note that 1.0 is in feature freeze permenantly, so only bug fixes go in
> there.
>> Afaik the release branches receive changes related to packaging and
>> release process. After the release, those changes are merged back. Tim knows
>> more about the release process, so maybe he could add/correct.
> Thats correct. Branches are made at point or release, or by developers who
> want to work in a sandbox. Note that svn doesnt treat branches and tags any
> differently like CVS does.
> So if you are working in trunk, work here:
> https://trac.osgeo.org/qgis/
> And in the stable branch, work here:
> https://svn.osgeo.org/qgis/branches/Version-1_0
> Regards
> Tim
>> Regards,
>> Marco
>> -----Ursprüngliche Nachricht----
>> Von: qgis-developer-bounces at lists.osgeo.org im Auftrag von Radim Blazek
>> Gesendet: Mi 13.05.2009 12:11
>> An: qgis-developer at lists.osgeo.org
>> Betreff: [Qgis-developer] GRASS bugs commit
>> Hi,
>> I am going to fix some GRASS related bugs. I was not contributing to
>> QGIS for a while so I want to ask you where I should commit the fixes.
>> Into 'trunk' I presume? Into some stable branches also?
>> BTW, can you please clarify (or point me to some place were it is
>> explained) how release branching is done?
>> I see Version-1_0 branch which I suppose was used to create
>> Release-1_0_0, Release-1_0_1 and Release-1_0_2?
>> Release-1_0_1 was created from Release-1_0_0 or from Version-1_0?
>> I don't see any Version-1_1 while Release-1_1_0 was created already.
>> Why Release-1_x_x are branches, not tags? A release must be unique, right?
>> Radim
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
