AW: [Qgis-developer] OSGeo4W: Qgis 1.0.1
Hugentobler Marco
marco.hugentobler at karto.baug.ethz.ch
Wed May 20 16:00:12 EDT 2009
Hi Stephan
>* When I accidently delete the buttonbar of the printcomposer I cannot enable
> it again unless I restart the complete project again. Starting the
> printcomposer does not solve the problem.
This is a bug.
>* Transparent WMS-layers. The WMS-layers are not transparent, even if I force
> TRANSPARENT=true within the Connection-parameter-URL. With QGIS 1.0.0 it was
> possible though (both with PNG-formats).
Transparent=True in WMS only refers to background transparency (e.g. if you have a line layer, the lines will not be transparent, only the areas not covered by lines).
I think that the WMS transparency in the raster properties dialog is fixed in newer versions. Please try with 1.2 and fill a bug if the problem still persists.
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.osgeo.org im Auftrag von Stephan Holl
Gesendet: Mi 20.05.2009 08:01
An: qgis-developer at lists.osgeo.org
Betreff: [Qgis-developer] OSGeo4W: Qgis 1.0.1
Dear QGIS-devs,
currently I am using QGIS 1.0.1 from the OSGeo4W-packagefor a beginner cource.
I did not try the points with the recent releases of QGIS.
Some oddities were found:
* Using *.qml-files with saved styles work perfectly with shapefiles. If I
place the saved *.qml-file with the identical name as the shapefile it gets
picked up as soon as I load the shapefile. Where do I need to put
the *.qml-file for a PostGIS-layer?
* Are the linetypes for classifying a boundary of a polygon extendable? The
filling-pattern are extendable though.
* Projected shapefiles (with .prj-file) do not show the correct projection
inside the metadata tab within the properties-dialog.
If you feel that some points above mentioned are bugs I am happy to create a
trac-ticket soon.
TIA for your comments.
Best regards
Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
