[Qgis-developer] OSGeo4W: Qgis 1.0.1
Stephan Holl
stephan.holl at intevation.de
Fri May 22 04:52:26 EDT 2009
Hallo Marco,
"Hugentobler Marco" <marco.hugentobler at karto.baug.ethz.ch>, [20090520
- 22:00:12]
> Hi Stephan
> >* When I accidently delete the buttonbar of the printcomposer I
> >cannot enable
> > it again unless I restart the complete project again. Starting the
> > printcomposer does not solve the problem.
> This is a bug.
OK, please find it here: http://trac.osgeo.org/qgis/ticket/1711 (I have
taken the liberty to assign it to you)
> >* Transparent WMS-layers. The WMS-layers are not transparent, even
> >if I force
> > TRANSPARENT=true within the Connection-parameter-URL. With QGIS
> > 1.0.0 it was possible though (both with PNG-formats).
> Transparent=True in WMS only refers to background transparency (e.g.
> if you have a line layer, the lines will not be transparent, only the
> areas not covered by lines).
Yes, that is exactly what we needed (and I knew it was working once in
an earlier release).
> I think that the WMS transparency in the
> raster properties dialog is fixed in newer versions. Please try with
> 1.2 and fill a bug if the problem still persists.
The transparency inside the raster dialog works as expected, but the
WMS-image did not come as a transparent PNG.
However, I tried with trunk (r10835) and it worked (on linux though).
Any other ideas on the other topics I posted? Especially the
*.qml-thingy I am interested to get solved/answered.
TIA
Best
Stephan
> -----Ursprüngliche Nachricht-----
> Von: qgis-developer-bounces at lists.osgeo.org im Auftrag von Stephan
> Holl Gesendet: Mi 20.05.2009 08:01
> An: qgis-developer at lists.osgeo.org
> Betreff: [Qgis-developer] OSGeo4W: Qgis 1.0.1
> Dear QGIS-devs,
> currently I am using QGIS 1.0.1 from the OSGeo4W-packagefor a
> beginner cource. I did not try the points with the recent releases of
> QGIS.
> Some oddities were found:
> * Transparent WMS-layers. The WMS-layers are not transparent, even if
> I force TRANSPARENT=true within the Connection-parameter-URL. With
> QGIS 1.0.0 it was possible though (both with PNG-formats).
> * Using *.qml-files with saved styles work perfectly with shapefiles.
> If I place the saved *.qml-file with the identical name as the
> shapefile it gets picked up as soon as I load the shapefile. Where do
> I need to put the *.qml-file for a PostGIS-layer?
> * Are the linetypes for classifying a boundary of a polygon
> extendable? The filling-pattern are extendable though.
> cannot enable it again unless I restart the complete project again.
> Starting the printcomposer does not solve the problem.
> * Projected shapefiles (with .prj-file) do not show the correct
> projection inside the metadata tab within the properties-dialog.
> If you feel that some points above mentioned are bugs I am happy to
> create a trac-ticket soon.
> TIA for your comments.
> Best regards
> Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090522/3f9a5539/signature.bin
