[Qgis-developer] trouble with translation files
Jürgen E. Fischer
jef at norbit.de
Sat May 23 13:15:56 EDT 2009
Hi Alex,
On Sat, 23. May 2009 at 08:55:08 -0700, Alex Mandel wrote:
> Actually the issue is with QT 4.5 a quick hack to keep working is to
> remove all instances of the degree symbol and copyright symbol from all
> of the .ts files. Of course don't commit this back.
Why not? That doesn't do any harm - I fixed that twice in r10600 and r10257
and now the problem is back. :(
I think that only happens when updates from translators are commited. Can
anyone confirm that is doesn't happen, when update_ts_files.sh is run?
That would also explain why this only affects a few and not all translation
files .
I don't know what translators use to update the ts files, but these tools
obviously don't care to only change things between <translation> and
</translation>.
E.g. the version and encoding attribute is removed or changed from the ?xml
tag, the language attribute from ts tag.
Removing encoding attribute might interfere with the degree and copyright
symbol and removing the language attribute breaks numerus forms.
IMHO translators should only change translations and not touch anything else.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
