[Qgis-developer] Re: [Qgis-user] feedback/bug report from a qgis
course based on qgis-dev
Andreas Neumann
a.neumann at carto.net
Sun Nov 15 09:25:44 EST 2009
Hi Giovanni,y
Thank you for reporting the bugs/problems and sharing your experience
with the QGIS course.
I wonder, however, if it is wise to teach a course with a trunk build?
While trunk builds are reasonably stable, the trunk currently
considerably changed and changes, both feature-wise and with the UI. It
may be strange if you teach your users based on trunk - tomorrow they
download QGIS-trunk and they find a different UI. Probably not the best
impression. Also, the trunk is definitely not polished yet and currently
can contain some inconsistencies.
So in my opinion it would be wiser to use QGIS mimas for courses or
introducing new users - or at least very, very clearly state that the
trunk is for development work not meant for production and changes on a
almost daily basis.
Some of my users use the trunk version as well (because we urgently need
some of the new features), but I very carefully check a nightly build
before upgrading the machines of my colleagues for not running into
unexpected surprises.
Just my opinion,
Andreas
Giovanni Manghi wrote:
> Hi all,
> we are in the middle of a course with a group of biologists and I would
> like to leave here some feedback.
> Attendees are using qgis trunk on both windows (xp, vista, seven) and
> ubuntu linux.
> Let me know if I have to open tickets for the problems here reported.
> *) under windows, the postgis manager plugin still have the bug reported
> here
> https://trac.osgeo.org/qgis/ticket/1911
> *) on some pcs (both linux and windows) the right-ctrl key doesn't works
> while using the "node tool"
> *) the "simplify feature" tool freezes/crashes windows (xp,vista,seven)
> if used on small *simple* polygons in a shapefile defined in a projected
> (20790) CRS and otfr on.
> *) the "split feature" tool randomly freezes/crashes qgis on both linux
> and windows when used on the very same features (in a projected -20790-
> CRS and otfr on).
> *) the "add part" tool randomly freezes/crashes qgis on both linux and
> windows when used on the very same features (in a projected -20790- CRS
> and otfr on).
> *) the "delete part" tool works only if ones clicks on a node of the
> part to be deleted. If the part is a polygon and one clicks on it, the
> tool doesn't works. Same conditions as above.
> *) when zooming a lot to see a node of a polygon (same conditions as
> above), qgis takes a lot to get trough it and ultimately crashes (seg
> fault) on both linux and windows.
> *) when using the "identify" tool the windows that pop-up is not the
> normal one, but the one that now I believe is called "view feature
> form". When identifying features randomly appears the standard dialog
> window. Happens on both linux and windows.
> For the third straight course it was possible to show that reporting
> bugs do actually works and works really fast. At the end of the first
> day I reported a problem with the label UI and the day after it was
> already fixed (thanks Tim!)!.
> Saluti
> -- Giovanni --
> Qgis-user mailing list
