[Qgis-developer] Value Tool does not work on 1.3.0
Agustin Lobo
alobolistas at gmail.com
Tue Sep 15 12:12:47 EDT 2009
(This message was sent through Nabble also but I've got a note stating
tha was
not distributed. Sorry if it is finally duplicated)
This does not seem to be the problem, as Value tool
does not work on intrepid either (I'm using 1.3.0.1~intrepid3)
On intrepid, the graphic window draws the axes but not the line
and both Profile and Scattergram work fine. But the value tool
does not print or plot the values.
On jaunty, the graphic window complains about qwt. Have
not tested Profile and Scattergram (will do it in the evening). And
value tool does not print the values.
So it seems there are 2 problems here, the most important one being
the one making value tool not printing the values.
BTW, I think that such a fundamental information as the raster value
should be
displayed on the bottom, just besides the position information. In some
packages (i,e, TNTmips) you see both the actual raster values (up to 3) and
the RGB of the color displayed (which do not necessarily match). Then,
an additional tool such as the current Value tool would provide additional
extended information.
Anyway, the urgent thing now is getting the value tool back working!
Agus
Borys Jurgiel-2 wrote:
Dnia poniedziałek, 14 września 2009 o 20:36:22 Agustin Lobo napisał(a):
> Using ubuntu jaunty, Value tool does not work with
> latest 1.3.0 from the ubuntugis repository. No error, just
> does not print the raster values.
> This is a very important tool, displaying raster values is
essential.
> Any help?
> Thanks
> Agus
Probably there is the same error with the Scattergram and the
Profile plugins?
I've noticed Jaunty had no appriopriate version of the PyQwt5
module, but
didn't check it last time...
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090915/a156b523/alobolistas.vcf
