[Qgis-developer] Suggestions: Save Project Prop.,
default directories, folder for shp files
Tim Sutton
lists at linfiniti.com
Fri Sep 18 05:58:03 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
Agustin Lobo wrote:
> Hi!
> Three suggestions:
> 1. It would be useful being able to save the settings
> in Project Properties as default for the next
> time Project Properties have to be set.
Yeah that would make sense.
> 2. Also, across all qgis and plugins, opening by
> default the last directory would be useful (or at least
> being able to set that behavior as default option in
> Options)
Yes
> 3. Finally, some tools create a folder for the set of files
> of a shp layer. I think this is useful ans should be
> done in all cases.
I prefer the files to go into the directory I specify, not a subdir. I
believe the behaviour is that if you specify a file name with .shp
suffix, it will create files in the current dir, if you leave of the
.shp it creates a dir with shapefiles in it. This seems like its already
ideal to me...
Regards
Tim
> Thanks for your attention.
> Agus
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkqzWasACgkQqk07qZdiYjcnZwCdEFMKJmByrAzCteEc44oA4L6Q
IO4AoNCvXPjRNoI+eEEcYqIVigwW/xyJ
=d00r
-----END PGP SIGNATURE-----
