[Qgis-developer] Suggestions: Save Project Prop., default directories, folder for shp files
Agustin Lobo alobolistas at gmail.com
Mon Sep 21 05:50:35 EDT 2009
Tim,
I agree that behavior would be ideal (leaving the
user free to decide), but this is not
what is always happening. For example, if you
use Save as Shapefile... and select
test as file name, you do not get a folder named
test.
Agus
2009/9/18 Tim Sutton <lists at linfiniti.com>
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi
> Agustin Lobo wrote:
> > 3. Finally, some tools create a folder for the set of files
> > of a shp layer. I think this is useful ans should be
> > done in all cases.
> I prefer the files to go into the directory I specify, not a subdir. I
> believe the behaviour is that if you specify a file name with .shp
> suffix, it will create files in the current dir, if you leave of the
> .shp it creates a dir with shapefiles in it. This seems like its already
> ideal to me...
> Regards
> Tim
> > Thanks for your attention.
> > Agus
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkqzWasACgkQqk07qZdiYjcnZwCdEFMKJmByrAzCteEc44oA4L6Q
> IO4AoNCvXPjRNoI+eEEcYqIVigwW/xyJ
> =d00r
> -----END PGP SIGNATURE-----
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20090921/d426412d/attachment.html
