[Qgis-developer] GPS Plugin Bug on windows
Tim Sutton lists at linfiniti.com
Tue Aug 10 12:15:17 EDT 2010
Hi
2010/8/9 Maurício de Paulo <mauricio.dev at gmail.com>:
> Hi folks,
> I've stumbled upon something that looks like this bug.
> http://trac.osgeo.org/qgis/ticket/1170
> The problem seems simples. I'm using QGIS 1.5 and Windows XP with a garmin
> gps.
> When calling gpsbabel from command line everything runs smoothly.
> When loading the data directly from the gps using qgis' plugin the "Invalid
> layer" message apear.
> The file is not even created and no signal comes from the gps.
> As a workaround I've edited the gps "Devices". I've changed from
> "%in" "%out"
> to
> usb: c:\test.gpx
> And everything worked fine.
> As far as I can see I'm stumbling upon some string replacing problem when
> changing from the "%out" to the actual path used in the plugin.
> When I changed just the "%in" to usb: I've found a %out file in my c:\
> folder. So the plugin is not working properly when replacing %out to the
> actual filename  I've found on the gui.
> Is someone able to reproduce it? I've tested on 3 machines. One linux
> (worked well) and 2 windows xp. None of the windows xp worked.
I tested here on Ubuntu 10.04 and wasnt able to successfully download
either without your fix or with it (I used /dev/ttyUSB0 for %in).
What string did you use for linux?
Regards
Tim
> 1º Ten Mauricio - Engenheiro Cartógrafo
> Chefe da Seção de Processamento de Imagens
> 1ª Divisão de Levantamento
> Exército Brasileiro - Braço Forte, Mão Amiga.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
