[Qgis-developer] Edit UI doesn't load the field's value
Giuseppe Sucameli
sucameli at faunalia.it
Wed Dec 8 04:17:30 EST 2010
On Wed, Dec 8, 2010 at 8:36 AM, Bernhard Ströbl <Bernhard.Stroebl at jena.de>wrote:
> no, I did not file a ticket for this, although I would support doing so.
I've filed it, here the ticket: #3308 [1]
Best regards.
[1] https://trac.osgeo.org/qgis/ticket/3308
If I customize the default edit-ui via "Layer Properties" - "Attributes" and
> choose a "value map" for a numerical field the resulting ComboBox shows the
> Strings I define but saves the values to the layer's table. I had expected
> the same behaviour with a custom ui but nope.
> Giuseppe Sucameli schrieb:
>> Hi Bernhard,
>> On Tue, Dec 7, 2010 at 7:56 AM, Bernhard Ströbl <Bernhard.Stroebl at jena.de<mailto:
>> Bernhard.Stroebl at jena.de>> wrote:
>> I can confirm this behaviour QGIS 1.5/WinXP, data from PostGIS
>> database.
>> Did you file a ticket yet?
>> My workaround is to have e.g. the QComboBox filled with values and
>> _additionally_ have a QTextLine named the same as the field in my
>> layer table holding the feature's current value. The QTextLine is
>> not visible to the user but gets changed if the user changes the
>> choice in the QComboBox by Qt'S Signal/Slot mechanism.
>> You're right, I understand that a developer can use the initFunction and
>> editForm
>> from API to bypass the issue, but how can users do the same?
> I do not think they can right now. They would need to do some Python
> scripting, a very good descrtiption is here:
> http://www.osgeo.org/pipermail/qgis-developer/2010-January/008731.html
> regards
> Bernhard
>> Thinking like an user, if I sets the edit UI from the layer property
>> dialog, the obvious
>> behaviour is that each combo must be populated and it must show the right
>> value
>> as the lineedit does.
>> If the combobox (but also the spinbox) doesn't show the right value, then
>> it's a bug.
>> Maybe did I start a thread on the wrong ML? Maybe I did.
>> But I hope we'll fix it quickly :)
>> Let me know if there's a opened ticket, otherwise I file a new one.
>> Thanks, and best regard.
>> all the best
>> Bernhard
>> Hi all,
>> it seems there is a problem with Edit UI dialog.
>> I have an .UI which contains a combobox and a spinbox.
>> When I edit a row using the Edit UI dialog, the combobox
>> PROVINCIA loads
>> all the values of the PROVINCIA field, but doesn't select the
>> current row value.
>> The spinbox does the same, it doesn't load the current value.
>> If I use lineedits instead, it works and loads the fields' value.
>> Loading only doesn't work, because if I change the value and and
>> press OK
>> the dialog stores the new value back into the field.
>> Does anybody confirm??
>> Cheers.
>> -- Giuseppe Sucameli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> ________ Information from NOD32 ________
>> This message was checked by NOD32 Antivirus System for Linux
>> Mail Server.
>> http://www.nod32.com
>> This message was checked by NOD32 Antivirus System for Linux Mail
>> Server.
>> Giuseppe Sucameli
>> This message was checked by NOD32 Antivirus System for Linux Mail Server.
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101208/c88e388f/attachment.html
