[Qgis-developer] info@borysjurgiel.pl
Agustin Lobo alobolistas at gmail.com
Fri Dec 10 14:00:24 EST 2010
Plugin Analysis/Point sampling tool should merge the table of
the point layer with the data extracted (at least optionally).
Otherwise the user must define
an ID for the new layer, (eventually also for the one with the sampling points)
and then use vector/Join Attributes.
Is the trac for plugins up?
Agus
