[Qgis-developer] Re: Enhanced constraint violation error dialog
while saving edits (feature request)
Stefan Keller
sfkeller at gmail.com
Wed Feb 10 14:15:48 EST 2010
What about my proposal for an enhanced error dialog when saving edits?
(Was my scenario too verbose?)
-S.
2010/2/7 Stefan Keller <sfkeller at gmail.com>:
> Dear all,
> I'm referring to the thread "Visualizing topology errors and
> supporting topology editing" and got a probably small feature request.
> Look at following scenario:
> Joe defines before hand some constraints in the database - say not
> null, uniqueness, etc. - or even topology rules.
> Then Joe captures and/or updates some features with their geometry and
> attributes.
> After having entered three objects he wants to check the validity and
> hits a shortcut to do this (similar to change edit mode).
> He then gets a list of two errors in a modal dialog. There, every line
> indicates the feature id and the constraint violation text.
> When clicking on such a line, the respective feature is highlighted.
> Up to now, AFAIK, there's only the possibility to "change edit mode".
> When clicking on it, a dialog entitled "Error while changing attribute
> values" pops up and says "ERROR: null value in column "prov2name"
> violates not-null constraint" - even when there are more than one
> features affected.
> So my proposal is:
> 1. Introduce a shortcut key to periodically "save/update edits"
> without leaving edit mode.
> 2. Enhance current Error dialog as indicated above.
> This would allow us to implement constraints and topology rules in the
> database without any scripting involved on the QGIS side (unless you
> want to set parameters interactively).
> What do you think?
> Regards, Stefan
