[Qgis-developer] Web mapping framework?
Andreas Neumann a.neumann at carto.net
Thu Jan 14 15:58:43 EST 2010
Hi Zoran,
For the client part I would recommend any of (or a combination of)
OpenLayers/GeoExt/MapFish. All three are related.
For the Server either UMN Mapserver or Geoserver is fine. There is also
a QGIS mapserver developed by Marco Hugentobler. Marco will work on it
later this year so you can re-use .qgs project files for web projects
(without having to write other config files). Meanwhile you can already
use QGIS  mapserver, but you have to write an SLD. It will serve the
data as WMS. UMN and Geoserver are certainly more tested and perhaps
faster than the current QGIS mapserver.
Marco can tell you more about QGIS mapserver.
Andreas
Zoran Jankovic wrote:
> Hi list,
> A little bit offtopic, but I promise I'll mention QGIS as well :-).
> I'm starting out a relatively small GIS project (read: no money
> involved, for at least next 6 months :-)). I've got the desktop part
> covered, GIS applications are nothing new to me (10+ years of
> experience), but we are interested in a web component as well.
> This web GIS component would be more for show than for real hevy-load
> usage... Layer on/off and some attribute searching capability are a
> must, of course...
> What I have now is QGIS, mainly shapefiles (still waiting for
> conversion to PostGIS...) created from DXF and TIFFs.
> I looked into Mapserver and Geoserver, and I'm kind of inclined to use
> Mapserver because of an existing GQIS plugin. But there are several
> "frameworks" I came accross googling: Mapfish, Geoext, worldKit, not
> to mention stuff that seems not to be developed any more, like Fusion,
> Chameleon, ka-Map!, etc, etc
> What are you using? Any recommendations, caveats? If I had time I
> would test a couple and share the results, but - time is money, and no
> money is involved (for now) in this project :(.
> Best regards,
> Zoran Jankovic
> ZIS-Izrada softvera i savjetovanje / ZIS - Software Development and
> Consulting
> http://www.zisis.hr
> M: 00 385 98 682 902
> T:  00 385 44 683 374
> A. Senoe 4
> 44320 Kutina
> Croatia
> Qgis-developer mailing list
