[Qgis-developer] annotation tools
John C. Tull
john.tull at wildnevada.org
Thu Mar 25 21:51:43 EDT 2010
Hi Marco,
I'm going to give this a try as it sounds very useful. I would note that the path to qgscomposermap.cpp is actually src/core/composer/qgscomposermap.cpp.
Thanks as always for your work,
John
On Mar 25, 2010, at 3:55 AM, Marco Hugentobler wrote:
> Hi devs
> I'd like to publish the first version of the annotation tools (that were also
> presented at the hackfest in Pisa) for testing:
> www.hugis.net/100324_annotation_tools.tgz
> Just copy it to you src/plugins/ directory and unpack. Then, insert
> 'annotation_tools' as new subdirectory into src/plugins/CMakeLists.txt. To
> make the items also appear in the print composer, you need to enable the lines
> 273 and 314 in src/core/qgscomposermap.cpp
> The plugin provides the functionality to place balloons for textboxes and
> designer forms on the map, providing various possibilities for symbolisations.
> At the moment, it is a plugin, but I'd like to bring the annotation classes
> into the gui library. What do you think?
> Regards,
> Marco
> Dr. Marco Hugentobler
> HUGIS GmbH
> Webereistrasse 66
> CH-8134 Adliswil
> marco at hugis.net
> http://homepage.hispeed.ch/hugis
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
