[Qgis-developer] Reverse Changeset 13499
Jürgen E. Fischer
jef at norbit.de
Wed May 19 06:02:42 EDT 2010
On Wed, 19. May 2010 at 20:26:11 +1200, Chris Crook wrote:
> I guess the point is that, as you rightly note, the feature count isn't very
> important, so having it wrong really doesn't matter. On the other hand
> having a responsive interface is important.
I did? Sorry, I didn't mean to.
What I can agree with, is that we often don't need a feature count and also
that the feature count often doesn't need to be accurate.
But I don't see any point in having a significantly wrong feature count, eg.
having the attribute table report that it found roughly all rows after a query,
although it actually shows only say five.
But I was asking if you have a where clause. Do you?
If you don't, I wonder how the change affects you and if you do, I wonder why
you insist on getting a wrong feature count - as would expect most where
clauses to limit the number of returned rows significantly.
And mentioning the mixed geometry case, was only to rule out the possiblity
that might have a where clause without knowingly having set one.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
