[Qgis-developer] GoogleLayers
Giovanni Manghi
giovanni.manghi at gmail.com
Tue May 25 04:02:21 EDT 2010
I was testing the plugin under windows and linux and I noticed the
following.
Under Windows (Seven , XP) sometimes it returns:
An error has occured while executing Python code:
File "C:\Documents and Settings\jirodrig/.qgis/python/plugins
\GoogleLayers\GoogleLayers.py", line 151, in run
z = min(max(int(ceil(log(min(width / ((x2 - x1) * 256), height /
((y2 - y1) * 256)), 2))), 0), 19)
ValueError: math domain error
Python version:
2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
QGIS version:
1.5.0-Trunk Trunk, 13555M
other times the error doesn't show, but the only tile it adds to the map
is ths one that shows the full extent on the world.
Under Linux (ubuntu) things seems to work better, but if I save a
project that includes one or more tiles, then when I try to reopen the
project qgis crashes with the following message
Error:
GDAL Error 6: No translation an empty SRS to PROJ.4 format is known.
Segmentation fault
cheers
-- Giovanni --
On Fri, 2010-05-07 at 18:45 +0200, Ivan Mincik wrote:
> > My problem is that the google layer never refreshes once it is loaded. I assume this is not the correct behavior, but maybe I am incorrect. Can anyone comment on this?
> Each Google tile is loaded loaded as separate layer, so You need to
> press button and load new layer again and again if You want another
> tile. So You can finish with 100 layers loaded at the end. This plugin
> is using Google maps static API, which was not build for flawless map
> browsing (which is blocked from non-browsers by Google). Whole plugin
> principle is nice hack.
> Ivan
> Qgis-developer mailing list
