[Qgis-developer] Interlis support of OGR inside QGIS (make it
default? modify make files? Windows but not only...)
Andreas Neumann
a.neumann at carto.net
Mon Oct 18 10:00:54 EDT 2010
Hi Stefan,
You should use Marco Hugentoblers Interlis plugin to load files, which,
like you said uses OGR. It just makes the OGR handling easier and allows
to select only certain topics/tables.
What exactly is the problem? What error message are you getting?
I believe that Interlis should be enabled by default by QGIS 1.5 or QGIS
1.6. It works on my machine for small and medium sized itf's but fails for
big itfs. I haven't tested Interlis 2 so far.
Andreas
On Mon, October 18, 2010 12:14 pm, Stefan Keller wrote:
> Hi,
> I'm trying to import/export INTERLIS geodata inside QGIS under Windows
> (XP Professional) - but had no luck so far.
> There are two QGIS plugins around, "OGR Converter" (C++) and
> "Interlis" (Python) which obviously call OGR/GDAL libraries.
> "OGR Converter" doesn't list Interlis format and "Interlis" plugin
> reports "The GDAL/OGR library you are using has beend compiled without
> Interlis support".
> I'm talking about INTERLIS format version 1 and 2 (read/write).
> I fear that the default make files for GDAL/OGR do not include
> INTERLIS libraries.
> I know also that there is a problem - at least under Windows and MacOS
> - of ogr/gdal accessing java jar packages (ili2.jar) unless they are
> copied in the default library search path - or even in every directory
> where programs and data reside.
> 1.Can anybody involved in delivering the (Windows) binaries and in
> committing to the "OGR Converter" and "Interlis" plugins have a look
> at this problem?
> => To me an optimal solution would be, that Interlis support is
> included by default in all QGIS deliveries.
> 2. Is there any workaround? Eventually I can replace the GDAL/OGR .dll
> (.so) myself?
> Yours, S.
> Qgis-developer mailing list
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
