[Qgis-developer] Interlis support of OGR inside QGIS (make it default? modify make files? Windows but not only...)
Stefan Keller sfkeller at gmail.com
Mon Oct 18 10:25:46 EDT 2010
I'm trying to use OGR in whatever plugin under QGIS and Windows XP.
The error reported in a QGIS window is "The GDAL/OGR library you are
using has been compiled without Interlis support".
I think you (and Horst too) are using Linux, so it seems to me I'm the
first user of the Interlis plugin :->?
The plugin "Interlis" (Python) mentioned before is the one from Marco
(via http://karlinapp.ethz.ch/python_plugins/python_plugins.xml)
=> Or do you mean another one?
Looking inside <settings>\.qgis\python\plugins\interlis\interlisplugin.py
there is an obious test:
Interlis support".
>    def run(self):
>        fileFilters = QgsProviderRegistry.instance().fileVectorFilters()
>        if not fileFilters.contains("Interlis",  Qt.CaseInsensitive):
>            QMessageBox.critical(None, QCoreApplication.translate("InterlisPlugin","No Interlis support available"),
>                                             QCoreApplication.translate("InterlisPlugin","The GDAL/OGR library you are using has been compiled
>        without Interlis support"))
Replacing C:\Programs\OSGeo4W\bin\ogr2ogr.exe did'nt help neither
which is weird, because calling the same ogr2ogr.exe out of a Windows
shell reports
     -f "Interlis 1"
     -f "Interlis 2"
as possible values.
Yours, S.
2010/10/18 Andreas Neumann <a.neumann at carto.net>:
> Hi Stefan,
> You should use Marco Hugentoblers Interlis plugin to load files, which,
> like you said uses OGR. It just makes the OGR handling easier and allows
> to select only certain topics/tables.
> What exactly is the problem? What error message are you getting?
> I believe that Interlis should be enabled by default by QGIS 1.5 or QGIS
> 1.6. It works on my machine for small and medium sized itf's but fails for
> big itfs. I haven't tested Interlis 2 so far.
> Andreas
> On Mon, October 18, 2010 12:14 pm, Stefan Keller wrote:
>> Hi,
>> I'm trying to import/export INTERLIS geodata inside QGIS under Windows
>> (XP Professional) - but had no luck so far.
>> There are two QGIS plugins around, "OGR Converter" (C++) and
>> "Interlis" (Python) which obviously call OGR/GDAL libraries.
>> "OGR Converter" doesn't list Interlis format and "Interlis" plugin
>> reports "The GDAL/OGR library you are using has beend compiled without
>> Interlis support".
>> I'm talking about INTERLIS format version 1 and 2 (read/write).
>> I fear that the default make files for GDAL/OGR do not include
>> INTERLIS libraries.
>> I know also that there is a problem - at least under Windows and MacOS
>> - of ogr/gdal accessing java jar packages (ili2.jar) unless they are
>> copied in the default library search path - or even in every directory
>> where programs and data reside.
>> 1.Can anybody involved in delivering the (Windows) binaries and in
>> committing to the "OGR Converter" and "Interlis" plugins have a look
>> at this problem?
>> => To me an optimal solution would be, that Interlis support is
>> included by default in all QGIS deliveries.
>> 2. Is there any workaround? Eventually I can replace the GDAL/OGR .dll
>> (.so) myself?
>> Yours, S.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
