[Qgis-developer] HTML manual [patch]
Martin Weis
martin.weis.newsadress at gmx.de
Wed Sep 1 15:32:51 EDT 2010
Hi!
Am 30.08.2010 09:42, schrieb Otto Dassau:
> i think we should put the html user manual on the task list for the hackfest
> in November in Wrozlaw. I could help with that there and then. I added a
> note to the Wrozlaw page.
> http://www.qgis.org/wiki/4._QGIS_Hackfest_in_Wroclaw_2010
> We can discuss the ideas and improvements now and add them to the
> ManualTasks (I started a new section):
> http://www.qgis.org/wiki/ManualTasks
>> Le 29/08/2010 16:56, Noli Sicad a écrit :
>> An html version of the latex manual is on my ToDo-list but it isn't as
>> simple as I expected. A latex version without any figures can be
>> compiled easily if needed.
I did not have many problems using tex4ht to convert to HTML, the output
seems reasonable. The OS images are a bit too big, though (huge penguins
At least with version [tex4ht.c (2009-01-31-07:33 kpathsea)] it is no
problem to convert it here.
Maybe a 'private' configuration would help (to split document, nicer
'buttons' etc.), according to:
http://www.cse.ohio-state.edu/~gurari/TeX4ht/mn-commands.html#QQ1-9-41By
the way, I found some bugs (\label inside caption), patch for evis part
attached...
There remain some similar label problems, e.g. in the following there is
no number defined for the graphics (no caption), and the label will be a
double of the previously defined one (e.g. a section):
plugins_gps.tex: \caption{\label{gpxloader}The \emph{GPS Tools} dialog
window \nixcaption}
for today I have to go, but I found some other dubious places using:
grep '{\\label{' *.tex
Bye,
Martin
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100901/162fe54c/plugins_evis.tex.bin
