[Qgis-developer] HTML manual [patch]
MORREALE Jean Roc
jr.morreale at enoreth.net
Wed Sep 1 16:01:11 EDT 2010
Le 01/09/2010 21:32, Martin Weis a écrit :
> Hi!
> Am 30.08.2010 09:42, schrieb Otto Dassau:
>> i think we should put the html user manual on the task list for the hackfest
>> in November in Wrozlaw. I could help with that there and then. I added a
>> note to the Wrozlaw page.
>> http://www.qgis.org/wiki/4._QGIS_Hackfest_in_Wroclaw_2010
>> We can discuss the ideas and improvements now and add them to the
>> ManualTasks (I started a new section):
>> http://www.qgis.org/wiki/ManualTasks
>>> Le 29/08/2010 16:56, Noli Sicad a écrit :
>>> An html version of the latex manual is on my ToDo-list but it isn't as
>>> simple as I expected. A latex version without any figures can be
>>> compiled easily if needed.
> I did not have many problems using tex4ht to convert to HTML, the output
> seems reasonable. The OS images are a bit too big, though (huge penguins
> At least with version [tex4ht.c (2009-01-31-07:33 kpathsea)] it is no
> problem to convert it here.
> Maybe a 'private' configuration would help (to split document, nicer
> 'buttons' etc.), according to:
> http://www.cse.ohio-state.edu/~gurari/TeX4ht/mn-commands.html#QQ1-9-41By
> the way, I found some bugs (\label inside caption), patch for evis part
> attached...
> There remain some similar label problems, e.g. in the following there is
> no number defined for the graphics (no caption), and the label will be a
> double of the previously defined one (e.g. a section):
> plugins_gps.tex: \caption{\label{gpxloader}The \emph{GPS Tools} dialog
> window \nixcaption}
> for today I have to go, but I found some other dubious places using:
> grep '{\\label{' *.tex
> Bye,
> Martin
I was trying with hevea with much less success, could you upload your
result ?
Thanks for the patch, I'll apply it to trunk.
