[Qgis-developer] problems with xp/osgeo4w
Tim Sutton
lists at linfiniti.com
Thu Sep 9 01:27:04 EDT 2010
Does installing the vcredist bundle help at all? Also check if there are no
stray dlls e.g. proj.dll. in your system dir that may be causing problems.
Depends.exe is a handy tool to use for tracing the problem.
Regards
Tim
On Sep 8, 2010 10:27 PM, "Giovanni Manghi" <giovanni.manghi at gmail.com>
wrote:
Hi all,
today I was testing osgeo4w on a windows 64 bit systems (see posts on
the users ml), but at some point I understand that something was wrong
also under 32 bit system.
I made a clean install of windows Seven 32 bit and no problems, but
under a clean installation of Windows XP 32 bit QGIS fails to start with
the following message:
the application failed to initialize properly (0xc01500002)
qgis-dev fails to run with the same message as does the standalone
version (QGIS-OSGeo4W-1.5.0-14109-Setup.exe)
cheers
-- Giovanni --
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100909/dd092b39/attachment.html
