[Qgis-developer] lock layers for map items
Paolo Cavallini
cavallini at faunalia.it
Mon Sep 27 01:55:04 EDT 2010
Il 26/09/2010 09:42, Marco Hugentobler ha scritto:
> Hi Paolo
> This option keeps the visibility (on/off) of the maplayers. Main use case is to
> have an overview map where not all layers are visible.
> As the composer uses the central QgsMapLayerRegistry, it is not easily
> possible to have a totally different set of layers as in the main canvas.
Thanks Marco for clarifying. So layers can be fixed, colors not.
I think sooner or later it will be good to have both options.
I'm going to open a ticket, if you don't mind.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
