[Qgis-developer] GSoC proposal: DBManager
Tim Sutton
lists at linfiniti.com
Wed Apr 6 01:56:59 EDT 2011
Hi Guiseppe
8<--------snip----------------
>> Proposal.
>> My aim is to merge both 3 plugins together and create the DB_manager plugin.
>> First and the most important requirement, the DB_manager plugin *must* be
>> easily
>> expandable to manage different kind of databases (e.g. mysql, ...).
>> I didn't look ahead when I forked PG_manager, but I want to correct my
>> mistakes.
>> Second, it should permit an easy management of databases, running common
>> tasks
>> as create/alter/delete tables, retrieve infos about tables, run queries, ...
>> Those are implemented in PG/SL_manager yet, but I have to do some changes to
>> make them more general than they are.
>> Third, DB_manager should allow to load tables as layer on the QGis canvas
>> and,
>> on the contrary, import layers from the canvas into the db.
>> What is your opinion? Did I miss something?
>> What other features would you like to see? And what other plugins (if any)
>> would it be
>> good to integrate in?
>> Thanks for your comments.
What about having some kind of plugin architecture (I know a plugin
with plugins is probably a bit meta!) so that other DBMS backends can
easily use your manager? I'm thinking that other backends like
SQLAnywhere could easily also benifit from your work just by
implementing a small stub for your plugin api....
I think you GSOC proposal would make a fantastic addition to QGIS and
I wish you all success with your proposal.
Regards
Tim
>> Giuseppe Sucameli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> ___________________________ ___ __
> Ricardo Garcia Silva
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
