[Qgis-developer] ecw and linux nightly builds
Jürgen E. Fischer
jef at norbit.de
Wed Apr 20 11:41:48 EDT 2011
Hi Ramon,
On Wed, 20. Apr 2011 at 23:17:07 +0800, Ramon Andinach wrote:
> I have also been looking at Jürgen's answer, and if I understand I should
> remove the remaining GDAL bits from the 1.6 install and bring in GDAL from
> source (which should be what the nightly build is expecting), and hook ecw up
> to that. Then it should work. I'm probably misunderstanding - is that right?
Not from source. The nightly builds use the GDAL version from the "original"
distribution.
My main point of the nighly builds is to test if trunk is building against the
various library versions - having usable trunk builds is just a side effect ;)
So if you need ECW support, you need to add it to that version. The version
from ubuntugis is probably a different one and therefore not used by nightly
build. And in turn having ECW support for that one, doesn't help.
You need to build the GDAL ECW plugin for the "original" GDAL version. The
tuturial can help with that. And once you added it, QGIS (including coming
nighly builds) will be able to use ECW.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
