[Qgis-developer] Re: Release plans for 1.7.1
Giuseppe Sucameli
sucameli at faunalia.it
Wed Aug 24 13:56:23 EDT 2011
Hi Andrea, Luca,
On Wed, Aug 24, 2011 at 5:48 PM, aperi2007 <aperi2007 at gmail.com> wrote:
> >I discovered that with QGIS 1.6-1.7 WMS connection never uses proxy
> >user/password authentication, this is a big problem in corporate
> >environments. I filed the bug #3844.
> We discovered that also the plugin repository never uses proxy
> user/password.
> Perhaps will use the same classes ?
It work only with proxy anonymous (without user/pwd).
QGis uses a QT class (QNetworkAccessManager) to handle the user
authentication,
so I would exclude this is a QGis bug.
Indeed if it were a QGis bug, e.g. an error in setting proxy host and port,
then connection shouldn't have to work also without authentication.
Both these problems may be related to a QT bug in NTLM(v2) authentication,
see at [1].
@Luca: running the python plugin installer under the proxy, does it work?
Regards.
[1] https://bugreports.qt.nokia.com//browse/QTBUG-17322
So to update the plugins we need to put the repositories in the white-list
> (very very bad practice for network administrators).
> Andrea.
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110824/4a073002/attachment-0001.html
