[Qgis-developer] Where to put plugins and documents ?
Alex Mandel
tech_dev at wildintellect.com
Thu Dec 15 12:38:16 EST 2011
On 12/15/2011 08:20 AM, Paolo Cavallini wrote:
> Il 15/12/2011 16:28, Alexander Bruy ha scritto:
>>> Is there a recommendation to share the sources (such as
>>> http://hub.qgis.org/projects/plugin-builder)?
>> To share plugin sources you can use any SCM service such as GitHub,
>> BitBucket,
>> Google Code etc, or even setup own repo. AFAIK there are no strict
>> recomendations
>> on this.
> IMHO it would be prefab to have a default location (git instance) for
> all plugins, otherwise we'll end up quickly with a mess, especially
> considering the number of plugins and plugin developers is quickly
> increasing, and many of them will be possibly broken during the move to
> 2.0 APIs.
> All the best.
There are 2 general choices that might make it easier - either put them
on hub which provides git repos on demand or github where we have an org
account. Though I need to check if the org put's it name on a github
repo if it counts against the org quota.
With the use of git there is not reason to have 1 single repo for all
plugins, that kinda defeats the purpose of using git where it's cheap
and easy to setup small repos per plugin.
Thanks,
Alex
