[Qgis-developer] MCELite: An experimental tool for multi-criteria evaluation (MCE)
JP Glutting jpglutting at gmail.com
Sat Jan 8 06:41:07 EST 2011
Thanks Paolo!
Good idea about the documentation. I will have to figure out how to do that
with Qt. I also need to work on some UML diagrams to show how it all works.
That is a bad bug - it shouldn't crash if it can't find a config file.  What
were you doing when it crashed? It looks like you were running a Boolean
overlay analysis without defining a results file, but it shouldn't allow you
to do that (I just tried, and it pops up an error dialog). Also, what OS are
you using?
I'll see if I can recreate the error, and put in some checks to catch it.
Thanks,
JP
On Sat, Jan 8, 2011 at 8:40 AM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> Il giorno ven, 07/01/2011 alle 17.43 +0100, JP Glutting ha scritto:
> > Hello All,
> > I just wanted to let you know that I have uploaded my tool, MCELite,
> > to the PyQGIS repository. I had to try a few times to get it uploaded,
> > but it seems to work when downloaded from the repository.
> > MCELite takes raster files representing decision criteria and analyzes
> > them using three types of multi-criteria evaluation (MCE): Boolean
> > overlay, weighted linear combination (WLC) or ordered weighted
> > averaging (OWA). It also does sensitivity analysis of the results of
> > an analysis. It hasn't been extensively tested, so it is marked as
> > experimental, but it does run on Windows, OS X and Linux. The package
> > includes documentation and soem sample data data sets and
> > configuration files (it reads configuration files in addition to
> > having interactive input).
> > Because I wrote it for a study project, I didn't use any existing code
> > (it turns out it wouldn't have been a problem, but I wanted to be
> > safe) and I rolled my own Raster object to do the overlay instead of
> > using rastercalc or something like that. I can still rewrite the back
> > end, but it would be a lot of work.
> > The big thing missing from the tool is any kind of fuzzy set
> > membership analysis. I couldn't find any plugins for QGIS, so you need
> > to create the input rasters with another tool, if you want to do any
> > kind of interesting analysis.
> > Anyway, feel free to try it out, and let me know when it breaks. I am
> > sure it still has tons of bugs.
> Tried, got an error:
> Traceback (most recent call last):
>  File "/home/paolo/.qgis/python/plugins/mcelite/MCELiteDialog.py", line
> 755, in accept
>    self.runAnalysis(snd)
> 780, in runAnalysis
>    self.qm.runQuery(self.progress)
>  File
> "/home/paolo/.qgis/python/plugins/mcelite/mcelite/QueryManager.py", line
> 700, in runQuery
>    self.writeMCEConfig()
>  File
> 572, in writeMCEConfig
>    fHandle = open(filename, 'w')
> IOError: [Errno 2] No such file or directory:
> '/Users/jpg/pyGIS/qgismcelite/examples/bool_osx_example_configuration_Bool.txt'
> Versione Python:
> 2.6.6 (r266:84292, Dec 26 2010, 22:48:11)
> [GCC 4.4.5]
> Versione di QGIS:
> 1.7.0-Trunk Trunk, 14993M
> Thanks for including the documentation. It would be useful if you could
> add an help/about button to read it directly form the plugin menu,
> better if in html.
> All the best.
> http://www.faunalia.it/pc
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110108/53d409cb/attachment.html
