[Qgis-developer] MCELite: An experimental tool for multi-criteria evaluation (MCE)
Paolo Cavallini cavallini at faunalia.it
Sat Jan 8 08:04:01 EST 2011
Il giorno sab, 08/01/2011 alle 12.41 +0100, JP Glutting ha scritto:
> Good idea about the documentation. I will have to figure out how to do
> that with Qt.
You can have a look to e.g. CAD Tools, a good example, I think.
> I also need to work on some UML diagrams to show how it all works.
That would be good.
> That is a bad bug - it shouldn't crash if it can't find a config file.
> What were you doing when it crashed? It looks like you were running a
> Boolean overlay analysis without defining a results file
Exact.
> what OS are you using?
Debian unstable.
All the best, and thank you.
http://www.faunalia.it/pc
