[Qgis-developer] The optimal size for SVG symbols
Andreas Neumann a.neumann at carto.net
Thu Jul 7 00:11:05 EDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Andrea,
There is no "expected size" of your SVG document. I would recommend
using a square size for your document.
Creating seamless patterns in SVG can be hard. The hard part is to make
sure that the tiles can repeat and one cannot see the tile borders.
Here is a small tutorial on how to create SVG patterns in Inkscape:
http://ffaat.pointclark.net/blog/archives/143-Creating-and-Adding-Custom-Patterns-to-Inkscape.html
I will later see at my workplace if I can find a pattern similar to what
you want.
For diagonal patterns I would recommend to create straight horizontal or
vertical lines and then set the pattern rotation. It is easier to create.
Note that in trunk there is now a new feature that allows you to
overwrite colors and other settings to re-use the same patterns for
different colors. See Sourcepole blog: http://www.sourcepole.ch/
Andreas
On 07/06/2011 10:00 PM, Andrea Peri wrote:
> Hi,
> I need to create many SVG symbol to use as fill for polygons rendering.
> Someone is preatty easy to do because the fill is a simple fill with
> diagonal lines.
> But some symbol is a more complex regular pattern of little object.
> I need to know the right size of the SVG symbol to have the correct reply of
> pattern without breaks.
> I try with 32x32 but it seem to be no optimal.
> An example:
> I need to do a fill with this pattern:
> I try to create a SVG with this pattern but when apply it the qgis renderize
> in this mode:
> I guess this is due to wrong size of my SVG symbol that not is optimal for
> the pattern.
> Bu I don't know the size that qgis need to have.
> thx,
> Qgis-developer mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJOFTHRAAoJELiCsGDopvBCI3EIAKPq0UCVuxf92Kszz3CFrVE2
QWZYSTxl5MOlKltMwqDQkUTtsK0VI/Lr5eyyIJj5xTZK5/kpYakLbF4vx8Vovmzv
aubBUhRpWCE/6Zikrr7z5Z5PC9QrV3UZ8Nws68GMJKvMGbmW3rOZCr/l7i9qhc8R
/sFX7kBzZ3CcjmIENltB4OUMAx9qd8FqY6JY9wIbfzVQMHl4eALcz5/SrBCigFIg
rZdje5PGyjjDwkHreuv5rMOJtDnWIVTjHzwgzwqP0k/SID/LzCe9uLL20HtquvtF
8HvTlslqBIl58uQLqusOiN9FJ1uDFOcfSrMbSxuhcvCPB0AkBLRNopODJA8QTug=
=D9nb
-----END PGP SIGNATURE-----
