[Qgis-developer] Re: Fwd: [Qgis-user] QgsVectorLayer causes
"Failed to load" error
Tim Sutton
lists at linfiniti.com
Thu Jul 7 05:38:41 EDT 2011
Hi
On Thu, Jul 7, 2011 at 10:35 AM, leonidas <leonidas_liakos at yahoo.gr> wrote:
> Running *locate libqgis_core.so * returns the following locations:
> /usr/lib/libqgis_core.so.1.6.0
> /usr/lib/libqgis_core.so.1.7.0
Remove all 1.6 packages and try again please - bad things happen when
you have both installed unfortunately.
Regards
Tim
> I installed qgis from ubuntgis repo and I'm using ubuntu 11.04
> I tried to use */usr* as prefix but also failed.
> Could it be something else the problem?
> Thanks for your help!
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fwd-Qgis-user-QgsVectorLayer-causes-Failed-to-load-error-tp6482726p6557564.html
> Sent from the qgis-developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
