[Qgis-developer] Qwt now required?
Tim Sutton
lists at linfiniti.com
Thu Jul 14 06:33:51 EDT 2011
Hi Again
On Thu, Jul 14, 2011 at 12:31 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi Dave
> 8<------------------snip----------------------
>> In the release announcement of 1.6 ( http://blog.qgis.org/node/146 ), it
>> states "Replaced raster histogram implementation with one based on Qwt", so
>> I'm guessing that that might be where the dependence came from. It's kind of
>> unfortunate that it became a required dependence for such a small addition,
>> but apparently that's the case and I'll just have to get it installed on all
>> my machines before upgrading to 1.7.
> Agreed but there was also a lot of interest for it to be included by
> default because a lot of plugin writers are using it. My apologies for
> the hassle. If you dont need it we could probably ifdef out the
> related bits out and make qgis build without it.
> That said are you not using just QGIS core and gui classes in your Qt
> app then? I'll need to check but we should not need to link those to
> Qwt, just the app.
Just to follow up on the above:
[gui] ldd /usr/local/lib/libqgis_core.so | grep qwt
[gui] ldd /usr/local/lib/libqgis_gui.so | grep qwt
[gui] ldd /usr/local/bin/qgis | grep qwt
libqwt-qt4.so.5 => /usr/lib/libqwt-qt4.so.5 (0x00007f568ec32000)
So on my system, only the qgis app itself links to qwt and you should
not need to link to it from your app at all.
Regards
Tim
> Regards
> Tim
>> Thanks,
>> Dave
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
