[Qgis-developer] QGis will only load WMS Layers in WGS84
Giovanni Manghi
giovanni.manghi at gmail.com
Sat Jun 11 08:26:39 EDT 2011
can you post the service URL?
On Sat, 2011-06-11 at 19:54 +0800, Hilmy Hashim wrote:
> I am using OSGeo4W qgis trunk revision 1b15528 on Windows 7 64-bit.
> I have several geotiff layers on Geoserver 2.1 in native srs of
> EPSG:3375. They display fine using Geoserver's preview layer.
> When I try to load them using QGis wms, they will only load when the
> project is set to EPSG: 4326. When I set the project to EPSG:3375,
> nothing is loaded. Changing the crs in the wms dialog doesn't help.
> Not sure if this is the same issue faced by Mike Leahy:
> http://lists.osgeo.org/pipermail/qgis-user/2011-May/012131.html
> Thanks for any pointers.
> Hilmy
> Qgis-developer mailing list
