[Qgis-developer] SpatiaLite very slow with QGIS 1.7
Cline, Royce L. rcline at nd.gov
Thu Mar 17 16:27:49 EDT 2011
Is this possibly a 64 bit issue. I am assuming Sandro's mini is an original core duo and therefore his build is 32 bit. Probably his test of the Identify Tool and Selection tool was on 32 bit Windows. If so, this could be the differentiating factor.
Royce
On Mar 17, 2011, at 1:31 PM, William Kyngesburye wrote:
> Some tests here, OSX 10.6.6:
> QGIS 1.6 with Sqlite/Spatialite 3.6.23/2.4rc3 framework
> add 20 spatialite layers: 2s
> quit: instant
> reopen: 2s
> QGIS 1.6 with Sqlite/Spatialite 3.7.4/2.4rc4 framework
> add 20 same layers: 2s
> quit: instant
> reopen: 3s
> QGIS 1.7 r15455 with Sqlite/Spatialite 3.7.4/2.4rc4 framework
> add same 20 layers: 2s
> quit: instant
> reopen: 3s
> I'll try updating my SVN and rebuilding and see if there is a change.
> On Mar 17, 2011, at 11:04 AM, Alessandro Furieri wrote:
>> Hi Noli, hi Royce,
>> I've just spent several hours attempting to build the
>> current QGIS-Trunk SVN snapshot on my cheap and old
>> second hand MacMini (incredibly slow hardware, really
>> an extenuating time consuming process ...).
>> Anyway, these are my personal findings:
>> - Mac Os X 10.5 Intel
>> - not using frameworks at all (only the Qt one)
>> - using MacPorts libraries instead
>> - and using INTERNAL SpatiaLite (2.4.0-RC4)
>> + QGIS on Mac Os X runs exactly as it run on Windows
>> + I was completely unable to observe any issue about
>> the Identify tool
>> + opening an 80+ layers DB takes an absolutely
>> reasonable time
>> + closing the same DB is a quite immediate process
>> So, I'm completely unable to tell you why the 'standard'
>> QGIS distribution for Mac Os X shows so many problems
>> related to SpatiaLite 2.4.0-RC4 as you've reported.
>> At this point I strongly suspect that something is
>> broken or misconfigured in the most recent SpatiaLite
>> Mac Os X framework, because simply avoiding to use
>> this one and building so to use the INTERNAL spatialite
>> instead fixes any issue.
>> bye Sandro
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
