[Qgis-developer] new ubuntu compile problem
Marco Bernasocchi
marco at bernawebdesign.ch
Sun May 1 16:22:25 EDT 2011
thanks MArtin, that did the job... i had done a make clean but was
obviously not enough ...
Now I still get the sip error below, i can't remember how i solved it
last time...
Couldn't load PyQGIS.
Python support will be disabled.
File "", line 1, in
RuntimeError: the sip module implements API v8.0 to v8.1 but the
qgis.core module requires API v7.1
Python version:
2.6.6 (r266:84292, Mar 25 2011, 19:33:11)
[GCC 4.5.2]
QGIS version:
1.7.0-Wroclaw 'Wroclaw', 15820M
ciao MArco
On 04/30/2011 06:14 PM, Martin Dobias wrote:
> On Sat, Apr 30, 2011 at 5:17 PM, Marco Bernasocchi
> <marco at bernawebdesign.ch> wrote:
>> Hi all, I just upgraded to ubuntu 11.04 and I've got two probs:
>> on one hand the python-sip version appeared aqain:
> Hi Marco
> completely remove your build directory, then configure, build and
> install qgis again.
> Martin
Marco Bernasocchi
www.bernawebdesign.ch
skype: mbernasocchi
