[Qgis-developer] new ubuntu compile problem
Martin Dobias
wonder.sk at gmail.com
Mon May 2 05:34:58 EDT 2011
Hi Marco
On Sun, May 1, 2011 at 10:22 PM, Marco Bernasocchi
<marco at bernawebdesign.ch> wrote:
> thanks MArtin, that did the job... i had done a make clean but was
> obviously not enough ...
> Now I still get the sip error below, i can't remember how i solved it
> last time...
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
> File "", line 1, in
> RuntimeError: the sip module implements API v8.0 to v8.1 but the
> qgis.core module requires API v7.1
I would expect that you have maybe an incompatible version of sip
generator and sip python module or something similar. Not sure though
about the cause.
Martin
