[Qgis-developer] new ubuntu compile problem
Marco Bernasocchi
marco at bernawebdesign.ch
Mon May 2 05:40:30 EDT 2011
Hi martin,
On 2 May 2011 11:34, "Martin Dobias" <wonder.sk at gmail.com> wrote:
> Hi Marco
> On Sun, May 1, 2011 at 10:22 PM, Marco Bernasocchi
> <marco at bernawebdesign.ch> wrote:
> > thanks MArtin, that did the job... i had done a make clean but was
> > obviously not enough ...
> > Now I still get the sip error below, i can't remember how i solved it
> > last time...
> > Couldn't load PyQGIS.
> > Python support will be disabled.
> > Traceback (most recent call last):
> > File "", line 1, in
> > RuntimeError: the sip module implements API v8.0 to v8.1 but the
> > qgis.core module requires API v7.1
> I would expect that you have maybe an incompatible version of sip
> generator and sip python module or something similar. Not sure though
> about the cause.
I look into it tonite. But i guessed a similar cause. Is it correct that
trunk needs sip api v 7?
Ciao
> Martin
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110502/3894ee27/attachment.html
