[Qgis-developer] new ubuntu compile problem
Martin Dobias
wonder.sk at gmail.com
Mon May 2 05:48:59 EDT 2011
On Mon, May 2, 2011 at 11:40 AM, Marco Bernasocchi
<marco at bernawebdesign.ch> wrote:
>> I would expect that you have maybe an incompatible version of sip
>> generator and sip python module or something similar. Not sure though
>> about the cause.
> I look into it tonite. But i guessed a similar cause. Is it correct that
> trunk needs sip api v 7?
No. QGIS does not care about sip api version. That is an internal
matter of SIP - it forbids running python modules using incompatible
spi api version to protect users from misbehavior (or crashes) due to
changes in SIP interals between incompatible sip releases.
Martin
