[Qgis-developer] new ubuntu compile problem
Mayeul Kauffmann
mayeul.kauffmann at free.fr
Mon May 2 14:58:46 EDT 2011
Hi Marco,
Myself I migrated to Ubuntu 10.10 and I had the python issue when
building r15676 last Saturday but Martin hint ("completely remove your
build directory") solved the problem for me.
My /etc/apt/sources.list contains the following:
deb http://qgis.org/debian-nightly natty main
deb-src http://qgis.org/debian-nightly natty main
Do you use one of the followings?
https://launchpad.net/~qgis/+archive/stable
http://les-ejk.cz/ubuntu/ # GIS for Ubuntu
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
Does are some I tend to use in the past and that are now commented out
in my sources.list
Hope it helps. Good luck!
Mayeul
Le lundi 02 mai 2011 à 11:48 +0200, Martin Dobias a écrit :
> On Mon, May 2, 2011 at 11:40 AM, Marco Bernasocchi
> <marco at bernawebdesign.ch> wrote:
> >> I would expect that you have maybe an incompatible version of sip
> >> generator and sip python module or something similar. Not sure though
> >> about the cause.
> > I look into it tonite. But i guessed a similar cause. Is it correct that
> > trunk needs sip api v 7?
> No. QGIS does not care about sip api version. That is an internal
> matter of SIP - it forbids running python modules using incompatible
> spi api version to protect users from misbehavior (or crashes) due to
> changes in SIP interals between incompatible sip releases.
> Martin
> Qgis-developer mailing list
