[Qgis-developer] new ubuntu compile problem
Luiz Motta motta.luiz at gmail.com
Mon May 2 23:08:45 EDT 2011
Marco,
I just upgraded to ubuntu 11.04 and had the same problem about
SIP(Couldn't load PyQGIS....)
I am running perfectly QGIS, to this i follow this steps:
1) Remove all files and directories in 'build' directory
2) Inside 'build' directory:
2.1) Set the makefile:
sudo ccmake ..
2.2) Make and install QGIS
sudo make
sudo make install
* in my case, i made update of sources(checkout from SVN)
3) Install the OSGEO binding for Python
sudo apt-get install python-gdal
* when updated the ubuntu, the system removed the OSGEO binding
Hope it helps.
Luiz
2011/5/2 Mayeul Kauffmann <mayeul.kauffmann at free.fr>:
> Hi Marco,
> Myself I migrated to Ubuntu 10.10 and I had the python issue when
> building r15676 last Saturday but Martin hint ("completely remove your
> build directory") solved the problem for me.
> My /etc/apt/sources.list contains the following:
> deb http://qgis.org/debian-nightly natty main
> deb-src http://qgis.org/debian-nightly natty main
> Do you use one of the followings?
> https://launchpad.net/~qgis/+archive/stable
> http://les-ejk.cz/ubuntu/  #  GIS for Ubuntu
> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
> Does are some I tend to use in the past and that are now commented out
> in my sources.list
> Hope it helps. Good luck!
> Mayeul
> Le lundi 02 mai 2011 à 11:48 +0200, Martin Dobias a écrit :
>> On Mon, May 2, 2011 at 11:40 AM, Marco Bernasocchi
>> <marco at bernawebdesign.ch> wrote:
>> >> I would expect that you have maybe an incompatible version of sip
>> >> generator and sip python module or something similar. Not sure though
>> >> about the cause.
>> > I look into it tonite. But i guessed a similar cause. Is it correct that
>> > trunk needs sip api v 7?
>> No. QGIS does not care about sip api version. That is an internal
>> matter of SIP - it forbids running python modules using incompatible
>> spi api version to protect users from misbehavior (or crashes) due to
>> changes in SIP interals between incompatible sip releases.
>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
