[Qgis-developer] new ubuntu compile problem
Marco Bernasocchi
marco at bernawebdesign.ch
Tue May 3 05:45:30 EDT 2011
thanks Mayeul,
I'm using ubuntu_gis_unstable, i now changed to debian nightly and it
works, as soon as I've time I'll look into the problem more..
ciao
Marco
On 05/02/2011 08:58 PM, Mayeul Kauffmann wrote:
> Hi Marco,
> Myself I migrated to Ubuntu 10.10 and I had the python issue when
> building r15676 last Saturday but Martin hint ("completely remove your
> build directory") solved the problem for me.
> My /etc/apt/sources.list contains the following:
> deb http://qgis.org/debian-nightly natty main
> deb-src http://qgis.org/debian-nightly natty main
> Do you use one of the followings?
> https://launchpad.net/~qgis/+archive/stable
> http://les-ejk.cz/ubuntu/ # GIS for Ubuntu
> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
> Does are some I tend to use in the past and that are now commented out
> in my sources.list
> Hope it helps. Good luck!
> Mayeul
> Le lundi 02 mai 2011 à 11:48 +0200, Martin Dobias a écrit :
>> On Mon, May 2, 2011 at 11:40 AM, Marco Bernasocchi
>> <marco at bernawebdesign.ch> wrote:
>>>> I would expect that you have maybe an incompatible version of sip
>>>> generator and sip python module or something similar. Not sure though
>>>> about the cause.
>>> I look into it tonite. But i guessed a similar cause. Is it correct that
>>> trunk needs sip api v 7?
>> No. QGIS does not care about sip api version. That is an internal
>> matter of SIP - it forbids running python modules using incompatible
>> spi api version to protect users from misbehavior (or crashes) due to
>> changes in SIP interals between incompatible sip releases.
>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Marco Bernasocchi
www.bernawebdesign.ch
skype: mbernasocchi
