[Qgis-developer] update pull request
Mayeul Kauffmann
mayeul.kauffmann at free.fr
Sat May 7 13:38:22 EDT 2011
Thanks a lot Tim for the detailed commands!
Will be useful for next time. While searching for documentation, I found
several very good diagrams (including the one on the qgis wiki):
http://osteele.com/archives/2008/05/commit-policies
http://blog.interlinked.org/tutorials/git.html
http://www.google.com/search?q=site:book.git-scm.com&um=1&ie=UTF-8&tbm=isch
from http://book.git-scm.com/
The most detailed graphic cheat sheet I found is here:
http://panela.blog-city.com/update_of_git_supervisual_cheatsheet.htm
But on the project page you find an even more detailed svg a python
script (I could not make it work, though, even after "sudo easy_install
pysvg)
I have added the first two of those here:
http://www.qgis.org/wiki/Using_Git
By the way, I also corrected the code formatting for braces in the,
er..., editing section of the "good formatting example" at:
http://www.qgis.org/wiki/Developers_Manual#Editing
(should we run astyle on code extracts in the wiki? ;-) )
Hope this helps,
Mayeul
Le samedi 07 mai 2011 à 18:28 +0200, Tim Sutton a écrit :
> Hi
> On Sat, May 7, 2011 at 6:03 PM, Mayeul Kauffmann
> <mayeul.kauffmann at free.fr> wrote:
> > Hi,
> > Thanks all for your hints. Still, I could not find a way to make those
> > changes on existing branch and on the pull request #3, so I forked again and
> > added a new pull request:
> Ok no need to refork, you can just do (in your local repo):
> git remote add qgis-upstream git://github.com/qgis/Quantum-GIS.git
> git fetch qgis-upstream
> git branch --track release-1_7_0 origin/release-1_7_0
> git checkout release-1_7_0
> git pull qgis-upstream release-1_7_0
> git push origin release-1_7_0
> That will pull any changes from qgis repo and push them up to your
> clone of it. Obviously you need to commit any fixes you made in
> response to the comments and push those too. Then just issue a new
> pull request and cancel the old one.
> I will write up some working practice docs in CODING soon I promise :-)
> Regards
> Tim
> > https://github.com/qgis/Quantum-GIS/pull/7
> > In the meantime, there was a new commit in the 1_7_0 branch.
> > (Yes, I know, it is "simple" to solve this but sorry, no, I'm not smart
> > enough yet...).
> > Sorry for those probably bad practices...
> > Mayeul
> > Le samedi 07 mai 2011 à 15:29 +0200, Sandro Santilli a écrit :
> > On Sat, May 07, 2011 at 12:40:18PM +0200, Mayeul Kauffmann wrote:
> >> I would have created a new personal repository forking
> >> the main one and started from zero, but since it is not possible to
> >> download a single branch, downloading all takes hours for me, so their
> >> might be another commit in the mean time... this way I will never catch
> >> up.
> > There's no problem importing changes from upstream, git pull merges
> > them in.
> > Optionally the --rebase switch acts like if you created patches
> > for your changes, updated the repository to upstream, and re-applied
> > those patches.
> > --strk;
> > () Free GIS & Flash consultant/developer
> > /\ http://strk.keybit.net/services.html
