[Qgis-developer] Re: Error_while _Compiling _Qgis_using _MSVC
Tim Sutton
lists at linfiniti.com
Fri May 13 05:19:22 EDT 2011
Hi Sunil
Maybe you should start a new thread since you seem to be talking about
linux issues now.
Some distros require you to add
/usr/lib64/grass64/lib
to your /etc/ld.so.conf
After adding it do
ldconfig
All above need to be done as sudo / root.
Regards
Tim
On Fri, May 13, 2011 at 7:38 AM, sunilrajkiran pichaimani
<sunilrajkiran at gmail.com> wrote:
>> Hi
> I have successfully compiled QGIS in both Windows and Ubuntu ,
> Thanks to all. But when I install QGIS in both, Though QGIS runs smoothly I
> could not able to load Grass plugin in both platforms, when I run in "debug"
> mode I find out the issue
> Failed to load: /home/kcubedev/binary/lib/qgis/libgrassprovider.so (Cannot
> load library /home/kcubedev/binary/lib/qgis/libgrassprovider.so:
> (libgrass_gis.so: cannot open shared object file: No such file or
> directory))
> But the file libgrass_gis.so is located in that mentioned location only
> Is that again the configuring issue or any other issue ?
> Can anyone please support me again to solve this issue ?
> Thanks and Regards,
> Sunil
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
