[Qgis-developer] Re: Error_while _Compiling _Qgis_using _MSVC
Tim Sutton
lists at linfiniti.com
Fri May 13 05:21:30 EDT 2011
Hi
On Tue, May 10, 2011 at 4:21 PM, sttsx <ssolak at tai.com.tr> wrote:
> You won't get much thing even if you follow the notes carefully. There are
> many things missing in windows installation instructions. There are tons of
> compilation errors. I could not fix them all and I give up after dealing
> many hours.
I don't believe this is true - I followed them on a clean windows a
month or two back and if you follow the instructions everything works
seamlessly.
If you have specific reproducable issues please post them here so that
we can improve the instructions further.
Regards
Tim
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-while-Compiling-Qgis-using-MSVC-tp6347394p6348026.html
> Sent from the qgis-developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
