[Qgis-developer] Projection widget improvement
Paolo Cavallini
cavallini at faunalia.it
Thu Nov 17 02:21:57 EST 2011
Hi all.
I think the projection widget should be improved, by having the search
filtering the projections rather than moving to the next matching (as it
happens e.g. in the plugin list). Also, it would be good to have the
search working in both fields (people often overlook the search field
selector). Finally, the internal projection ID could be hidden (I do not
see any use of it for the user).
If agreed, it's a trivial change.
All the best.
Paolo Cavallini
See: http://www.faunalia.it/pc
