[Qgis-developer] tests FAILED:, 19 - qgis_stylev2test
Etienne Tourigny
etourigny.dev at gmail.com
Sat Aug 18 06:20:03 PDT 2012
Someone disabled this test, but this needs to be fixed.
This is due to color ramps not being saved by the new style manager
(both in app and in tests).
They appear in the style manager after creation, but are not loaded
when qgis is restarted. Other symbols are saved fine.
Martin, can you please fix this?
Thanks,
Etienne
On Thu, Aug 16, 2012 at 11:34 AM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Hi
> The test that fails is testSaveLoad(). After merge of Arun's work,
> test script was not updated for changes to saving and loading of
> symbols.
> I wrote that test file. To make sure it doesn't mess with user's
> settings, and also to make sure tests are independent of user's
> settings I setup a "test" environment $HOME/.qgis_test and
> QGIS_TEST.conf.
> IMHO I think it would be wise to do that for other tests.
> Etienne
> On Thu, Aug 16, 2012 at 11:12 AM, Marco Bernasocchi
> <marco at bernawebdesign.ch> wrote:
>> The following tests FAILED:
>> 19 - qgis_stylev2test (Failed)
>> any ideas?
>> freshly pulled
>> ciao
>> Marco Bernasocchi
>> http://opengis.ch
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
