[Qgis-developer] tests FAILED:, 19 - qgis_stylev2test
Tim Sutton lists at linfiniti.com
Sat Aug 18 07:28:56 PDT 2012
Hi
On Sat, Aug 18, 2012 at 3:20 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Someone disabled this test, but this needs to be fixed.
> This is due to color ramps not being saved by the new style manager
> (both in app and in tests).
> They appear in the style manager after creation, but are not loaded
> when qgis is restarted. Other symbols are saved fine.
> Martin, can you please fix this?
Thanks Etienne - I agree it is better to leave broken tests rather
than disable them as they indicate something isnt working as it
should.
Regards
Tim
> Thanks,
> Etienne
> On Thu, Aug 16, 2012 at 11:34 AM, Etienne Tourigny
>> Hi
>> The test that fails is testSaveLoad(). After merge of Arun's work,
>> test script was not updated for changes to saving and loading of
>> symbols.
>> I wrote that test file. To make sure it doesn't mess with user's
>> settings, and also to make sure tests are independent of user's
>> settings I setup a "test" environment $HOME/.qgis_test and
>> QGIS_TEST.conf.
>> IMHO I think it would be wise to do that for other tests.
>> Etienne
>> On Thu, Aug 16, 2012 at 11:12 AM, Marco Bernasocchi
>> <marco at bernawebdesign.ch> wrote:
>>> The following tests FAILED:
>>>          19 - qgis_stylev2test (Failed)
>>> any ideas?
>>> freshly pulled
>>> ciao
>>> Marco Bernasocchi
>>> http://opengis.ch
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
